Program development using keithley 2001, keithley 6221 and GPIB card KPCI-488LP in LabVIEW 7.1 environment for 4 wire measurement
Hello Sir/Madam
I want to develop a program using keithley 2001, keithley 6221 and GPIB card KPCI-488LP in LabVIEW 7.1 environment for 4 wire measurement because there is no software support by  Keithley for above mentioned instruments combination. In this regard please help me for software development, installation, configuration and communication for 4 wire measurement in window xp environment.
Malik Ishfaq
(4,188 Views)
 Thanks for reply. Sir I have downloaded drivers for Keithley 6221 and Keithley 2001 but donot have any material for 4 wire measurement and code examples. Actually I want to develop a program using keithley 2001, keithley 6221 and Keithley GPIB card KPCI-488LP in LabVIEW 7.1 and window xp environment for 4 wire measurement because there is no software support by  Keithley for above mentioned instruments combination. In this regard please provide me code examples and other related guidance.
(4,148 Views)
If you would like to learn more about resistance measurements, you can check out the tutorial here: http://zone.ni.com/devzone/cda/tut/p/id/3981
Considering the unique application you are building, I would suggest that you spend time consulting the documentation for each of your devices as well as taking a look at the material offered on NI.com. By searching on NI.com, you can find tuturials, examples, and KnowledgeBase articles that could help you learn how to perform your measurements. Another good resource is the Example Finder in LabVIEW (LabVIEW >> Help Menu >> Find Examples). There are hundreds of data acquisition and programming examples there.
(4,124 Views)
Thanks for reply and guidance. Any one can tell me about code examples for any company instruments for 4 wire measurement except NI like this combination keithley 2001, keithley 6221 and GPIB card KPCI-488LP in LabVIEW 7.1.
(4,118 Views)
