08-13-2006 05:48 PM
08-14-2006
06:59 PM
- last edited on
03-09-2026
09:43 AM
by
Content Cleaner
Without more information, it is hard to diagnose the problem in your application. Here are some links that describe some possible solutions to time-out errors.
VISA Troubleshooting Wizard - Timeout Errors
http://www.ni.com/support/labview/visa/verr2.htm
Why do I Receive Timeout Error -1073807339 on VISA Write?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019L3mSAE&l=en-US
VISA TCP/IP Resource Read Timeout
http://digital.ni.com/public.nsf/websearch/383FA277AE7A364F862571020074F3EA?OpenDocument
Error -1073807339 When Using VISA Read in a Serial VI
What hardware are you using? What function causes this time-out? Please let me know if one of these links helps!
08-14-2006 07:09 PM
08-14-2006 07:10 PM
08-14-2006 07:11 PM
08-16-2006 07:35 AM
One thing I noticed is that you do not open and close a VISA session with your instrument. LabVIEW will open a session as needed, but it is better to open a session in the beginning and close it a the end of your application. Also, you can wire the VISA resource session all the way through the sequence structure, as you are using the same instrument throughout. I modified your VI to include this. Attached is the modified VI.
If you run this modified VI, do you see the same error? If you run the VI in highlight execution mode, which write fails?
