errError; [Code = 10109] Control HW Communications Disabled with thorlabs BSC101 andmotorized filter wheel FW103/M
Hi everybody!
I want to communicate to my thorlabs motor with labview but it's don't work whereas with APTuser its work.
I put you the pictures of my program I did and error's pictures in attachements.
Thx you
Message 1 of 9
(7,691 Views)
I retry this morning and it's work >< I don't know why maybe because I restart the computer... But now it's APT utility doesn't work...
Any answer or question? 😃
Thx.
Message 2 of 9
(7,667 Views)
Here the error message I received.
Message 3 of 9
(7,665 Views)
Hi Gael,
I think this a problem of refnum.
Can you try to close the reference at the end of your VI ?
Message 4 of 9
(7,641 Views)
Even I am having same problem with TDC001 controller from ThorLabs. Were you able to sort out the problem?
Message 5 of 9
(7,469 Views)
Did you guys get answer for Error; [Code = 10109]?
I have same problem TST001 stepper motor controller...
thanks
Message 6 of 9
(6,080 Views)
Hi everyone.
I'm having this exact problem with my TDC001.
I had an excellent program running with it for the past 15 months on my desktop and then all of the sudden a week ago I get this error. I've tried re-booting the computer and also attaching to other usb ports and still no luck.
I hooked it up to my laptop and ran APTuser and it worked fine. Why out of nowhere (after over 1000 runs of my program) does my desktop all of the sudden no communicate with this product?
Message 7 of 9
(5,776 Views)
I also have the same problem. Have you solved the problem? Could you please give me some suggestions?
Thank you for your kind help.
Ridong
Message 8 of 9
(5,338 Views)
Have you solved the problem? I also come across the same problem. Could you please give me some suggestions?
Ridong
Message 9 of 9
(5,335 Views)
