06-24-2013 07:05 AM
the last attachment: the program
06-24-2013 08:51 AM - edited 06-24-2013 08:56 AM
Moreover, my Function Generator AFG320 uses the Duty Cycle only with PULSE mode. This waveform is not in selection list !
This IVI is curious...
06-24-2013 06:26 PM - edited 06-24-2013 06:26 PM
Would you mind posting an I/O Trace capture while running the example?
Performing a Good NI I/O Trace Capture for Debugging/Troubleshooting
http://digital.ni.com/public.nsf/allkb/282C5D41E2BA04F2862574BA007803B9?OpenDocument
06-25-2013 06:57 AM
I made an I/O Trace capture: first attachment. Second attachment is I/O Trace Options.
There are several devices turned-off on GPIB: VNA ANRITSU, Multimeter, Capacitance-meter and Oscillo. I only turned-on the Functions Generator AFG320.
06-25-2013 02:15 PM - edited 06-25-2013 02:20 PM
Hello Adrien,
After reviewing the IO Trace capture, we noticed that it did not include the commands expected of the example. The previous IO Trace recorded commands to find resources and parse the results. We were expecting a series visa open, set/get attribute, read/write, and close commands.
Would you mind getting another capture? We need a capture of the commands executed while the example is running. I've attached an image of commands from a similar example for an Agilent Device to help give us an idea of what the trace should look like.
06-26-2013 02:48 AM
sorry
I think this time it's the right.
06-26-2013 02:08 PM
Hello Adrien,
Would you please try to run the original ivi-specific example (the icons will have a blue background)?
We will need to also verify that you run the example program in its original form, without any modifications (no added property nodes or other changes) and let us know if that runs without any errors using the AFG320?
Oh, and please make sure that the waveform control is set to Square.
06-27-2013 04:05 AM
I executed the first attachment program.
The I/O Trace result is the second attachment.
The icons of original ivi-specific driver are bleu. ( The icons of Class-IVI driver are green)
In my opinion, the good waveform is not square. On the Frequency Generator, Duty Cycle work with only PULS waveform. But this waveform does not exist in the waveform list of IVI-Driver.
I can controled the Duty cycle with VISA using PULS waveform: third attachment.
Thank you,
Adrien
