I've installed all the neccesary hardware to communicate with my instrument. NI recognizes my instrument, and vice versa. I thought if I type a GPIB command using NI-488.2 Communicator, click "Query", the reading result would be displayed. The command(s) do work b/c I see the instrument's parameters/readings change. So What I want is to be able to see the results on my PC, not only on my instrument. Is there a process I should be using,
1. Query, 2. Write, 3. Read, that I don't know about.
Thanks.
