12-16-2015 04:18 PM
I have a Compact Rio 9068 running the NI Linux Real-Time OS. I wanted to attach a GPIB-USB-HS+ to add a GPIB interace to it. My Problem is that I cant seem to install NI-488.2 on the 9068. I have it installed on my computer, and in MAX I have the option to install 488.2 on a PXI controller I have, but It will not give me the option to install it on the Compact RIO chassis. Is there no NI-488.2 for the NI Linux Real-Time OS? I cant seem to find anything about it in any documentation.
Mike
12-17-2015 12:18 AM
12-17-2015
09:28 AM
- last edited on
03-07-2024
04:01 PM
by
migration-bot
Hi Mike,
If you want to add a GPIB interface to the cRIO, you could use a GPIB-RS232 converter or the GPIB-RS485/422 converter with the RS-232 or RS-485 serial ports on the cRIO 9068.
Lauren
Applications Engineer
12-17-2015 10:57 AM
That is what I suspected. I was only trying to use the USB converter because thats what I had lying around. Thanks for the Help.
