communication between two computers
hello, I'm getting a problem, can someone help me or give me an idea?
I need to run a VI on a computer 1 and run another VI on a computer 2, what is the best way for the computer to get information from computer 2 through labview? and how can i do that?
(2,413 Views)
You could send data across the TCP/IP primitives between the two systems provided they maintain their IP addresses.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,406 Views)
My preference is using TCP/IP with the STM library.  My second choice is the Network Streams.  If you need raw throughput, then the Network Streams is the way to go.  Otherwise, there is little difference between these two as far as pros and cons.
(2,349 Views)
