communicating with par 273
most of the rs232 cables don't seem to be wide enough for our purpose. the rs232-c connection on our device has 13 pins. is there an additional adaptor that can be bought to make it fit?
Message 11 of 15
(1,166 Views)
Message 12 of 15
(1,164 Views)
A 25 pin to 9 pin adapter would NOT work with a 13 pin adapter. I don't think I've ever seen a DB13.
Message 13 of 15
(1,153 Views)
i meant a 25 pin sorry
Message 14 of 15
(1,149 Views)
I really have no idea. If it is a straight through, you still might need to swap pins to get a null modem connection. The information should be contained in the manual. What does it tell you to use? You have that - I don't.
Message 15 of 15
(1,144 Views)
