command misundertanding
Hello All,
Im using JPIB API build in Java to GPIB communication and I have a curious problem which I can not find out why?
When I send some initialization commands like :
*CLS; *RST ;STAT:PRES<LF>
*SRE0;*ESE0;:CONF:LOC:STAT CURR<LF>
The instrument interprets like this:
*SRE1
*SRE1
It put the "*SRE1" before the commands,
Does anybody have some tip?
Thanks in advance,
marcio
(3,139 Views)
It might be a problem caused by the instrument's command parser.  If there is such a problem when you send multiple commands in a line (with concatenating by semicolons), try to send each command separately.  It may work.
By the way, 488.2 common commands require a white-space between the header and parameter.
Therefore *SRE1 shall be replaced with *SRE 1  It is also true for *ESE.
(3,102 Views)
