We have a Windows 2000 system that recently upgraded it's GPIB driver to version 2.4 from version 2.1, soon thereafter we started getting blue screen crashes (on the order of once a week on a system that is constantly in use - 24x7). The bugcheck error reported by windows was: "0x0000001e (0xc0000047, 0x8042dc0c, 0x00000003, 0x00000000). Microsoft Windows 2000 [v15.2195]." A WinDbg analysis of the resulting crashdump is included below which shows the error in nipalk.sys. The module gpibprtk is at the top of the call stack.
The system has a PCI-GPIB board and a NI PCI-232 16 port RS-232 board. The application software uses NI-VISA to communicate with the hardware. The following software versions are installed:
| Name |
Version |
Description |
| NI-488.2 Software |
2.40 |
Controller & Analyzer Software |
| Measurement & Automation Explorer |
4.0.0.3010 |
Use Measurement & Automation Explorer to manage your National Instruments products and services |
| NI-USI |
1.0.2 |
NI Universal Storage Interface |
| NI-PAL Software |
1.10.0f0 |
NI-PAL Library for Windows |
| NI-Serial Software |
1.8.0 |
RS-232 & RS-485 Driver Software |
| NI Spy |
2.3.0.49152 |
Monitors National Instruments API calls |
| NI-VISA |
3.4.1 |
Virtual Instrument Software Architecture |
| visa32.dll |
3.4.0.49152 |
VISA Library |
| NIvisaic.exe |
3.4.0.49152 |
VISA Interactive Control Utility |
| LabVIEW Run-Time |
8.0 |
LabVIEW Run-Time Engine |
I am guessing that this problem was introduced with the install of Version 2.40 of the GPIB driver since we did not see this particular bugcheck during 2 years of operations running version 2.1. Does anyone know at what version this may have been introduced? Is there any other work-around to avoid the problem? Any help would be appreciated.
thanks,
Dan
* Bugcheck Analysis *
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: c0000047, The exception code that was not handled
Arg2: 8042dc0c, The address that the exception occurred at
Arg3: 00000003, Parameter 0 of the exception
Arg4: 00000000, Parameter 1 of the exception
Debugging Details:
OVERLAPPED_MODULE: ati2drad
EXCEPTION_CODE: (NTSTATUS) 0xc0000047 - An attempt was made to release a semaphore such that its maximum count would have been exceeded.
FAULTING_IP:
nt!KeReleaseSemaphore+38
8042dc0c 85db test ebx,ebx
EXCEPTION_PARAMETER1: 00000003
EXCEPTION_PARAMETER2: 00000000
DEFAULT_BUCKET_ID: INTEL_CPU_MICROCODE_ZERO
BUGCHECK_STR: 0x1E
LAST_CONTROL_TRANSFER: from f74bd110 to 8042dc0c
TRAP_FRAME: f5d4e51c -- (.trap fffffffff5d4e51c)
ESP EDITED! New esp=f5d4e8cc
ErrCode = 00000000
eax=00000000 ebx=00000001 ecx=00000000 edx=00000000 esi=8599ecc4 edi=00000002
eip=8042dc0c esp=f5d4e590 ebp=f5d4e8e0 iopl=0 nv up ei pl zr na po nc
cs=0000 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000246
nt!KeReleaseSemaphore+0x38:
Resetting default scope
STACK_TEXT:
f5d4e8e0 f74bd110 8599ecc4 00000000 00000001 nt!KeReleaseSemaphore+0x38
WARNING: Stack unwind information not available. Following frames may be wrong.
f5d4e90c f5b985e6 ffffffff 00000000 f5b89d9d nipalk!tSyncAtomicI32::operator=+0x830
f68f9938 85cb6f00 00000008 00000000 80011347 gpibprtk+0x125e6
f5bac678 f5b9fe90 f5b9fe00 f5b9ff20 f5b9fde0 0x85cb6f00
f5b9fdb0 00000018 082444f6 56077401 602815ff gpibprtk+0x19e90
FOLLOWUP_IP:
nipalk!tSyncAtomicI32::operator=+830
f74bd110 c20400 ret 0x4
SYMBOL_STACK_INDEX: 1
FOLLOWUP_NAME: MachineOwner
SYMBOL_NAME: nipalk!tSyncAtomicI32::operator=+830
MODULE_NAME: nipalk
IMAGE_NAME: nipalk.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4333476d
STACK_COMMAND: .trap fffffffff5d4e51c ; kb
FAILURE_BUCKET_ID: 0x1E_nipalk!tSyncAtomicI32::operator=+830
