02-12-2007 07:48 AM
02-12-2007 07:59 AM
I know exactly what you are going through. By simply writing an ack response after my command I was able to get it to work. Try contacting the manufacturer of your instrument to see if there is anything missing from the manual they gave you. Sometimes they leave things out which are obvious to them.
Regards
02-12-2007 08:12 AM
02-12-2007 08:31 AM
Hey moralofa,
This obviously differs from the other commands seeing how it is a query command, not a control command. Query commands state that each method should either perform an action, or return data to the caller, but never both. With your timeout error I can only assume that you are returning data to the caller, but have no way of doing it at this point.
Has this command ever worked for you? If so, what response did you get. The " *** " or "Parameter Error".
02-12-2007 08:36 AM
02-12-2007 08:43 AM
02-12-2007 09:06 AM
02-12-2007 09:09 AM
02-12-2007 09:13 AM
02-12-2007 09:18 AM
