04-02-2007 02:36 PM
04-03-2007 11:38 AM
04-03-2007 03:12 PM
04-06-2007 11:40 AM
12-06-2007 09:02 PM
12-30-2008 06:41 PM
On my scope the switch on the backside named "calibration"
solved the issue when set to "unprotected".
When the scope arrived at my place it was set to "protected" and the same error messages from the selftest arised.
kind regards
Tom
05-07-2010 03:30 AM
I've a HP 54501a. The display shows the following message: address error 00005E4EH, to clear cycle power with one front panel key pressed .If the error condition remanins please consult the service manual.
Noboby key works, and the same message remains. Could be the Nvram who doesn't works correctly. The nvram is a dallas ds 1235Y type, impossible to change battery. Who can help me?. Thanks
05-10-2010 06:15 AM
Hi Frengo,
You should probably ask HP support for help, unless the behavior you've seen is somehow related to National Instruments software or hardware. In that case we would need a more detailed description of the issue.
Thanks for understanding.
Barna D.
06-05-2010 03:56 PM
I have an HP 54501A and the power supply went bad. Please provide recommendations on how to repair or replace this part. Perhaps I can find another malfunctioning 54501 that still has a good power supply...
Thank you!
06-05-2010 07:02 PM
