cRIO 9014 & RS232
I'm taking my first steps with a cRIO 9014 - for a VI running on the FPGA target, is it possible to use the RS232 port on the cRIO as an output?
(3,745 Views)
Accepted by topic author SamD
Hi SamD,
In answer to your question I am making a couple of assumptions. I assume your VI is running on the FPGA in your cRIO. In this case, the short answer is no. Only the Real-Time target can access the serial port so you would need to provide an interface between the Serial port (running on the RT target) and the FPGA.
I have also attached a Knowledge base article that explains how to implement RS-232 with NI FPGA hardware but you would need to add some additional hardware to do this. I would recommend the Developer Zone article.
I hope this helps,
Many thanks,
Andrew McLennan
(3,701 Views)
