 SamD
			SamD
			01-03-2009 03:23 PM
01-06-2009 04:26 AM
Hi SamD,
In answer to your question I am making a couple of assumptions. I assume your VI is running on the FPGA in your cRIO. In this case, the short answer is no. Only the Real-Time target can access the serial port so you would need to provide an interface between the Serial port (running on the RT target) and the FPGA.
I have also attached a Knowledge base article that explains how to implement RS-232 with NI FPGA hardware but you would need to add some additional hardware to do this. I would recommend the Developer Zone article.
I hope this helps,
Many thanks,
