basic serial write and read cannot read a second time
Hi, I'm trying to develop my own VI to write and read from an iRobot Create.  I based my vi off the Basic Serial Write and Read.vi example I found (on LabView 8.0).  When I run my vi I am able to read the beginning information from the Create, but I am unable to read a second time (after writing a command).  The second read should be the same as the first (I checked using a different program that is linked to the Create).  I am new at using LabVIEW and I was wondering if there is a common mistake made when trying to implement a serial read and write.
Thanks.
Message 1 of 9
(4,772 Views)
Did you check if there are characters to read with bytes available at port?
Message 2 of 9
(4,744 Views)
It says there are 0 bytes at port, but if the write works properly, it should read 135 bytes.  This is why I'm confused.  I know I'm not reading anything because the bytes at port = 0, but there should be bytes to read.  I'm really stuck and I don't know what else to try.
Message 3 of 9
(4,725 Views)
Then it sounds like the write is not working. Don't make the assumption that the write is working if you don't get an error. You will seldom get a VISA error with a write. For example, you can be sending garbage to the instrument. The instrument will not process it and as far as VISA is concerned, no error has occured.
Attach your code.
Message 4 of 9
(4,722 Views)
This is the code I've been trying to get things working.  Like I said, I'm new to LabVIEW so any insight would be helpful!
Message 5 of 9
(4,717 Views)
I'm unsure of what you are doing. You are first doing a read without doing a write so what is the point of the write command after you've done the read? Does the instrument actually require you to do a write? If you do have to perform a write, is the command formatted correctly? You do not have the Write Buffer control set the same way as the basic example so that could be a major problem. You have not provided the actual command you are sending and it would be nice to see the instrument's programming manual.
Message 6 of 9
(4,715 Views)
When I first turn on the iRobot, it sends some "welcoming/reset information."  I was using the first read to read that info.  The write is then supposed to send the reset command, I should then receive the same "welcoming/reset information" as before.  I can now do that.  I cannot send other commands to the iRobot successfully.  I'm thinking this is a problem I'm having with formatting the commands, but I have no idea how it's incorrect.
As for in LabView, is there an easy way to set up a "pause" until a button is pushed?  I'm thinking of a while loop that continues until a button is pushed and that will be the loop condition.  Is the best way to implement this pause?  (I have a large while loop around the write and read and want to send the write command only when I push a button.)
Thanks for all the help.
Message 7 of 9
(4,705 Views)
Accepted by RachtheSabu
First, debug your commands with a program such as Hyperterminal. If it works there, then it should work in LabVIEW. You may need to send a carriage return and/or line feed (\r\n). Your code is not currently set up to do that.
Only doing something when a button is pressed is basic LabVIEW programming. You can use a simple while loop with a front panel Boolean wired to a case statement. If you have anything other than the base version of LabVIEW, you should be using the event structure. Look at the examples that come with LabVIEW.
Message 8 of 9
(4,703 Views)
Using Realterm I was able to understand the commands better, thanks for the recommendation!  I have since been able to get the iRobot working.  Thanks for all your help.
Message 9 of 9
(4,669 Views)
