about vxi error message
I have two questions.
I have already set  "true" to "lockDevice"
but when I use another client to connect the server, it still can be connected.
and then when I want to command the server, a error message (error=15 I/O TimeOut) will appear.
Do anyone knows what happen?? the spec says if I set "true" to "lockDevice"  the server should not be able to linked by anotherclient.
lockDevice is in the struct listed below.
struct Create_LinkParms {
    long clientId; /* implementation specific value.*/
    bool lockDevice; /* attempt to lock the device */
    unsigned long lock_timeout; /* time to wait on a lock */
    string device<>; /* name of device */
 and one more question,
In server side, if I want to check if any error occurs, is it any priority needed??
for example,
device_write error values
error 0 =  no error
error 4 = invaild link identifier
error 5 = parameter error
error 11 = device locked by another link
error 15 = I/O timeout
error 17 = I/O error
error 23 = abort
which one do I need to check first??
Thanks a lot.
(3,919 Views)
Hi Clowndoll,
I'm having a little bit of trouble understanding what exactly you're asking. What device(s) are you using when you see this error? You are referring to a client/server setup, so how exactly is this set up? What is your client and what is your server?
Justin E
National Instruments R&D
(3,906 Views)
Hi Justin
The Clients are two PC, and the Server is a instrument. The situation is, when I use the first PC to connect to my instruement, it works well, and then I set LockDevice = 'true'
After that, I think the second PC should not be able to connect to my instrument, cuz the spec says that.
But when I try to use the second PC to connect to my instrument, it still can make a link.
The error will apear when I try to use the second PC to command my instrument.
Error 15 - I/O Timeout.
Is this correct??But I think the error should occur when the second PC try to connect to my instrument to make a link.
Thanks for your patient.
(3,873 Views)
Clowndoll,
It seems like when the second client tries to connect, "Error 11 - device locked by another link" should be the error that is returned.
What instrument are you connecting to? Is it one of our VXI instruments?
Justin E
(3,859 Views)
