[Xcode 4.4] Linker error GPIB framework
I am encountering issues with the NI488 framework after upgrading to Xcode 4.4.
Here are the details:
After upgrading Xcode from 4.2.1 (4D502) to 4.4 (4F250), the GPIB Framework did appear in red color in the navigator (The same way missing files do when they are still referenced in the project but removed from the file system). The issue is that the said framework is still accounted for in the appropriate location (/Library/Frameworks/...). And the only thing I did was install the newer Xcode version and re-open the project.
So, I did remove the framework, and added it again to the build phase of the target app. When Adding it, I noticed that the framework was not offered to me as a choice and I that I had to select it "manually". This, I thought, is not an issue since I had to do the same operation to add VISA and nidaqmxbase frameworks, in a similar way under Xcode 4.2.1.
Then, the compiler was unable to find the headers declared as:
import <NI488/NI488.h>
so I was forced to use the full path:
#import </Library/Frameworks/NI488.framework/Versions/2/Headers/NI488.h>
to get the compiler to oblige. And now, I am stuck with the linker error:
ld: framework not found NI488
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Any ideas on how to solve this ?
Best Regards.
Additional informations :
In both case (under Xcode 4.2 and Xcode 4.4) base sdk is 10.7, target is 10.7. App is 32 bits.
Versions of the frameworks (VISA, 488, DAQmxBase) are the latest available on NI website.
Message 1 of 9
(5,297 Views)
Hi sci01,
I think that your issue is more an Xcode issue and how you declare the framework than a NI 488 framework issue.
You could probably join a Xcode developer forum to get an answer.
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
Message 2 of 9
(5,145 Views)
Accepted by topic author sci01
Thank you for your reply.
Actually I solved the issue yesterday morning. Here are my conclusions:
There are two sources to this error
1. The GPIB, VISA, and DAQmxBase installers don't install their framework in the appropriate location. So the linker can't find them.
2. Telling Xcode where to find the frameworks doesn't work since apparently, the information doesn't propagate to the linker.
1. Installing the GPIB, VISA, or DAQmxBase packages as usual.
2. Finishing the installation manually by moving the frameworks to the appropriate location.
Message 3 of 9
(5,138 Views)
Message 4 of 9
(5,138 Views)
Ok, perfect.
Best Regards
Message 5 of 9
(5,133 Views)
This is slightly off-topic, but I had to comment when I saw the action at the bottom of your posting with the NI-France information. That auto-show of a graphic when hovering over the text; AWESOME! How did you code for that???
Dave
Message 6 of 9
(5,114 Views)
OK, the newer versions of the XCode expect frameworks in different place (relative to "/Applications/XCode/.." now, rather than the old "/Library/Frameworks" where VISA installs its frameworks)...however, you do not need to move VISA frameworks at all... Simply go to your project and in your target's "Build Settings->Search Paths" add "/Library/Frameworks" to "Framework Search Paths" setting.... that's all...
Message 7 of 9
(5,029 Views)
Thanks for yoyr reply. This is now a solved issue (as far as I am concerned anyway). But, of course, I tried what you suggest [implied in my original message], but it didn't work at the time.
I can't tell if this is still the case. But currently, I have other pressing and serious issues with one of these frameworks (DAQmx base) that are keeping me busy, so I don't have the time to investigate.
Note: I also tried to create aliases or symbolic links to the frameworks instead of copying the full frameworks. It didn't work either.
Message 8 of 9
(5,020 Views)
Hi sci01,
I do realize from your point of view you are sorted....i'm just adding this info for others who like me run into the same VISA problem when upgrading the XCode.
Framework search path does propagate to the linker - here is an snipet of linking stage ouput from XCode 4.5.2 build:
"... -F/Library/Frameworks ..."
Message 9 of 9
(5,011 Views)
