Will NI Spy ever support Command Line options or have an API?
It would be useful to programmatically control NI Spy (start and stop capture), and redirect the output to a console inside an application.  Is NI open to ever expanding NI Spy's capabilties in such a way?
Message 1 of 10
(6,596 Views)
I second that question immediately
greetings from the Netherlands
Message 2 of 10
(6,585 Views)
I'm sure NI is open to consider all suggestions from their customers. You should submit a suggestion in the Product Suggestion Center.
In the meantime, you may want to consider using a third-party automation tool, such as AutoIt. This is fairly easy to use and has an ActiveX interface, so you can program NI-SPY operations by using AutoIt as a go-between.
Message 3 of 10
(6,561 Views)
I took your advice and submitted a suggestion at NI's Product Suggestion Center.
Message 4 of 10
(6,542 Views)
Hi all,
We've been thinking about programmatic access to NI Spy, but don't have specific plans for it.  Your input would be helpful.
We would like to know what your use cases are for an NI Spy API.
What kinds of features would be helpful in those use cases?
Gavin Fox
Systems Software
Message 5 of 10
(6,525 Views)
It would probably motivate NI to incorporate such a feature if more users would show an interest.  Please post the ways you would use such a feature on this discussion list.  Thanks!
Message 6 of 10
(6,465 Views)
Second that.  Have NI Spy start/stop programmatically and write to more places than a file, e.g. a queue.
Message 7 of 10
(6,028 Views)
Accepted by kcoggins
The latest version of Spy, 2.7, contains a LabVIEW API that allows you to start and stop captures. You may get it by installing VISA 4.6.
Song Du
Systems Software
National Instruments R&D
Message 8 of 10
(5,700 Views)
That is nice.  Where are the VIs to control it that are referenced on the online help, and are they LV 8+ only?
Message 9 of 10
(5,620 Views)
If you haven't found them yet, they are under Measurement I/O >> NI Spy.  The LabVIEW API is supported on versions 8.5 and above.
Jeremy L.
Message 10 of 10
(4,735 Views)
