Why is asynchronous reading from rs232 executed synchronous in VISA 3.0.1 under Windows XP?
When i use viReadAsync to read asynchronous from the serial port the function isn't executed
asynchronous, but synchronous and returns (after timeout) with VI_SUCCESS_SYNC.
I have enabled events (IO_COMPLETION) and installed a handler for IO_COMPLETION.
I use VISA (3.0.1) for Visual C++ under Windows XP.
Does anybody know why the viReadAsync() function isn't executed asynchronous?
(3,530 Views)
You can never force VISA to do something asynchronously, you can only request it. You are making the correct calls, but NI-VISA Serial code just isn't set up to do callbacks for I/O unless your requested byte count is above some threshold.
You can set that threshold in MAX. Go to "Tools>>NI-VISA>>VISA Options..." and change the field "Minimum Async Transfer" to a lower value.
This threshold is used for all hardware interface types when the lower-level driver does not intrinsically support the VISA asynchronous requirements for the desired event mechanism (queueing or callback). In other words, this threshold does *not* apply to GPIB because NI-488 implements asynchronous I/O for both queueing and callbacks.
Dan Mondrik
(3,530 Views)
