What is the difference between iblck and CriticalSection
I am programming multi-thread application with Visual C++ on Windows 2000. Each thread calls 488.2 routines.
Should I use iblck for each ibxxx calls? Or is it OK to use WIN32 CriticalSection instead?
(3,454 Views)
iblck is used for acquiring a lock for a particular board for use by the current process. The intent of iblck is to allow a process to deny other processes from accessing a GPIB board while that process is using it. iblck cannot be used to protect access to a GPIB interface from other threads within the same process.
A CriticalSection is used to protect access to a portion of code. From MSDN documentation on Critical Sections: "When multiple threads have shared access to the same data, the threads can interfere with one another. A critical section object protects a section of code from being accessed by more than one thread. A critical section is limited, however, to only one process or DLL and cannot be shared with other processes."
I belie
ve what you are looking for is a mutex. A mutex is intended to be used to protect access to a shared resource, such as a GPIB board. Again from MSDN documentation: "A mutex object is a synchronization object whose state is set to signaled when it is not owned by any thread and non-signaled when it is owned. Its name comes from its usefulness in coordinating mutually exclusive access to a shared resource. Only one thread at a time can own a mutex object."
I think that the code you're going to write may look something like this:
HANDLE hMutex = CreateMutex(NULL, FALSE, "GPIBMutex");
WaitForSingleObject(hMutex);
ibwrt(ud, "Send a request to instrument");
char responseString[RESPONSE_SIZE];
ibrd(ud, responseString);
ReleaseMutex(hMutex);
Refer to your MSDN documentation for more information on mutexes and other synchronization objects. Please post again if you have more questions.
Craig
(3,454 Views)
Craig,
Thank you for the very helpful response.
ttakai
(3,454 Views)
