Voltcraft IR 1200-50D Infrared Pistole
Hello together,
I have some problems with the device "Voltcraft IR 1200-50D".
I want to read all available values via LabVIEW. Interface is USB.
What I did:
  • correct WIN-driver installed
  • opened connection
  • read values (max temp, min temp, and so on...); checked if beginning of the data transmission sting is "FFFF" and and is "AA", see attached document.
  • close connection
What happens:
  • Sometimes correct values are displayed
  • Sometimes totally wrong values are dispayed
  • when I run this VI in a loop, it crashes always afer 2nd run...
Did somebody already implement that device in LabVIEW?
Has someone an idea what's wrong with my program?
Thanks for your help in advance.
Br Kris
(3,189 Views)
Since it appears that you are receiving hex, setting the 'Enable Termiantion Character' input to True is incorrect.
(3,176 Views)
