03-08-2012 01:59 PM
I have a new NI 488.2 GPIB card installed in a computer running Windows XP and I would like it to control a Perkin-Elmer AAnalyst300 spectrometer. The card was recommended by Perkin-Elmer and seems to be installed properly, along with the related software.
When trying to communicate with the instrument I get an error that both the GPIB and spectrometer are using address "0" (too many listeners). I have been unable to change the spectrometer value to "1" as listed in the "Set-up Wizard". I have tried setting the GBIP to 1, but get the same error.
Any help is greatly appreciated.
03-08-2012 02:04 PM
What set up wizard are you talking about? There is no NI software that will change the address of an instrument. Have you read the instrument manual?
03-08-2012 04:23 PM
Dennis,
The "Set-up Wizard" is the NI 488.2 one. You can see a bit of it in the document I attached.
No, I have not fully read the AA Manual, however, it doesn't give much technical info. It is chiefly an operator's guide.
The original set-up files were on diskettes and updated software for the this model machine was recently provided on CD by the manufacturer.
Is the machine address a hardware (dipswitch?) or software setting?
Thanks for the reply.
03-08-2012 04:33 PM
Well, as I said, you cannot change the instrument's address with the NI software (or anyone else's software for that matter). That ability is not part of the IEEE-488.s spec.
The address could be set from the front panel or dip switches. Most modern instruments from Tek, Agilent, etc., use the front panel. Many other instruments will use a dip switch. Some instruments will also require you to actually choose GPIB communication mode with the front panel.
