Visa read error
 I am controlling an actuator (newport TRA25, SMC100 controller) through the serial port. I keep getting the error -107380729 which in occurs from a VISA read procedure. Sometimes the error disappears when I go into highlight execution mode and sometimes it appears when I go into this mode. I don't understand why. I posted the portmon output for the two cases
The difference is at the IRP_MJ_READ command near the end where for the correct case "1TS00000A.." is read while for the other "." appears.
 Any ideas for what the problem is?
Magnus
(3,466 Views)
That's not a valid error code. Could you double check that and attach the VI you have written?
(3,443 Views)
