07-08-2009 04:55 PM
I have been writing a GPIB Labwindows Program using ViPrintf statements and also tried ViWrite statements in place of ViPrintf.
With the instrument I am communicating with I get Timeout Popups stating that the Operation did not complete before the Timeout
occurred.
Any Ideas?
Thank You,
Gary
07-09-2009 11:56 AM
I rewrote the program so that I used ibwrt and ibrd I get errors with this other program such as ENOL Timeout. When I have timeout set
for 10 seconds it still times out. It is not because of VISA library It is looking like the problem is the Physical connection or the device I am trying to talk to.
07-09-2009 03:43 PM
The box I was sending messages to required that I read the messages right after writing one message. And I disabled Serial Polling. Addiitionally
after reading the responses immediately and displaying the responses I found out which messages were not accepted by the box.
Messages accepted without errors do not timeout.
07-09-2009 04:15 PM
Hey Gary,
Thanks for posting all the steps you went through thus far
! After reading the messages after writing, are your timeout errors eliminated?
07-10-2009 06:33 AM - edited 07-10-2009 06:36 AM
Hi Justin,
Yes, I was getting timeouts after sending a message that was faulty. By reading all responses immediately after sending a message I could identify the bad message.
After a bad message was sent the Instrument, the Instrument will expect a *CLS to clear the instrument. If I just send messages back to back without reading the responses and I send a bad message the next message I send after the bad message will timeout because the instrument will no longer respond. The instrument is waiting
to be cleared.
Thank You,
Gary
