VISA read problem
Hi everyone,
I am using LabVIEW 2023 Q3 32 bits and I want to communicate with a COM port using the VISA functions. It used to work in the past but something may have changed and I can't figure out what.
When I use a VISA read command, I receive the correct answer from my instrument as long as I don' ask long databytes. I want to read 65536 bytes and I receive only 4096 whatever the timeout I put.
Message 1 of 12
(2,682 Views)
Please attach your code (in LV2019 or earlier) and more detail of your instrument to guide you better.
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
Message 2 of 12
(2,642 Views)
When I need to read more than 4k of data, I tend to read in chunks.  This is simply a VISA Read inside of a FOR loop.
Message 3 of 12
(2,617 Views)
unfortunately, my LV code is only in LV2023 now.
Message 4 of 12
(2,613 Views)
My LV code worked fine in previous versions with 64 kB of data and it is not working well now.
The software dedicated to the instrument works fine but with LV I can address several instruments/motors... and make some scans.
Do we need to clear the buffer before addressing a new command ? I am wondering if remaining data in the buffer would cause my problems
Message 5 of 12
(2,612 Views)
All that you have to do is goto File menu, select save for previous version and select 19.0
https://www.ni.com/docs/en-US/bundle/labview/page/saving-for-a-previous-version.html
Santhosh
Message 6 of 12
(2,601 Views)
I hope it is ok now for reading in LV2019
Message 7 of 12
(2,595 Views)
Now I put a VISA I/O buffer to 65536 but the VISA read command does only read 3741 bytes (it should read 65534).
Why is so ?
Message 8 of 12
(2,567 Views)
You didn't attach anything
Santhosh
Message 9 of 12
(2,560 Views)
Accepted by YvesM_91
Why is so ?
Potentially the data contained the termination character and hence VISA treated the data is complete.
Santhosh
Message 10 of 12
(2,558 Views)
