VISA interface
I have NI Vb 8012 for measurement. I wanted to know whether it is visa-compatible. if yes, Kindly do tell how to get visa ID string. Is it necessary to install any additional drivers for this device to be controlled by visa.
(3,382 Views)
You should install the driver for the VB-8012 located here
https://www.ni.com/en-us/support/downloads/drivers/download.virtualbench-software.html#324215
Curt
(3,289 Views)
Which visa software do I need to install for this process. I need this device to be controlled by another software and I need to write the visa ID string to the software. I am beginner to this field and I have little knowledge about it. Kimndly do help me out.
(3,270 Views)
What language are you using to write your application?
Curt
(3,246 Views)
I need my device to be controlled by another software named "infas Vibro 2.0", which is a software for laser interferometer measurement. The software can control all visa compatible function generators by using visa resource name.
Dennis
(3,210 Views)
After you install NI-VISA, open NI-MAX and plug in the VB 8012.
You should see the device show up under devices along with the resource name.
I'm not sure if it will work as a stand alone signal generator with your software.
Curt
(3,205 Views)
