VISA can't find oscilloscope connected through Ethernet (LAN)
I'm using Labview 8.5.1 and installed VISA 4.5. I connected my computer to an Agilent DSO5014A oscilloscope through an ethernet cable. I installed the corresponding driver  (I even tried the 2 versions found here http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=10256).
In "Measurement & Automation Explorer" though, after clicking on "Devices and Interfaces" and then "new", the device is not automatically found and the manual entry of IP Adress is not more successful. (I checked that my Ethernet port works and the cable aswell)
Any idea?
(5,841 Views)
No answer... Am I missing something obvious or did I post in the wrong category ? Or no one has got a clue?
(5,824 Views)
Hi Felix,
have you tried to ping the scope:
  • Start -> Ausführen (run) -> cmd.exe
  • ping IP_ADRESS_OF_SCOPE
A very common reason is, that the firewall is enabled. You may deactivate it from here: Start -> Systemsteuerung (Settings) -> Windows Sicherheitscenter (Secury Center) -> Firewall -> Disable
Are you able to find the scope in MAX (Measurement and Automation Explorer) now?
Best regards
Marian Vorderer
(5,823 Views)
Thanks for the answer.
I guess the Firewall was the problem. It finally worked but still not automatically recognized. I had to enter manually the IP adress.
Thanks for your help!
(5,819 Views)
Accepted by felix_and
Well, the IP - thing seems to be related to the AGILENT driver. Sorry, but I have no possibility to test it, because I do not have of one of these scopes. By the way: great timing 🙂
Best regards from Munich
Marian Vorderer
(5,816 Views)
It must be on the same subnet and also support VXI-11 device discovery to be automatically recognized when you are adding the TCP/IP resource.
-NathanT
(5,805 Views)
