VISA Write From File: Time between sending data
does anybody know, if there is a timedelay between the written data when using "VISA Write From File"? The help just says: "The data is then written to the device."
My problem is, that I have to download a firmware via this VI and there mustn't be a pause of more then 300msec between two data. If a longer pause occured, a timeout in the Power On would occur and the Firmwaredownload aborts.
Thanks in forward!
(3,231 Views)
The delays involved are normally les than a few ms. If 300 ms occurs your memory is so low that disk swapping is in action.
greetings from the Netherlands
(3,212 Views)
