Shared USB port execution
Hi:
I use a USB to RS-232 (8x) hub and I created a SubVI to read data via a COM port using VISA. Everything works fine.
When I try to execute two instances of the same SubVI in parallel (by putting two instances of the same VI on the block diagram with different COM ports as inputs), the SubVIs do not execute at the same time but sequentially. Which settings will allow to execute the SubVis in parallel and share the USB port?
Thanks!
Dan
(3,838 Views)
Please remeber that USB is also a serial line so two ports on the same usb bus never can run simultaneously
greetings from the Netherlands
(3,818 Views)
Accepted by topic author Dan10
Hi Dan10
Have you tried
" VI>>Properties>> Excecution >> Reentrant Execution(Checked) " ?
You should be able to communicate with
- different instances of the same program(VI) on the different ports...does not matter USB, serial, GPIB.
Does this work for you?
(On the other hand you want to access the same port, then you may have to isolate your 2 instances (as GUIs) talking to the same underneth driver resource.)
(3,805 Views)
Great. It works.
Thanks!
(3,784 Views)
