VISA Serial read error
I´m trying to read data from my OHM60 Heratherm oven with a RS-232 cable and Visa Test Panel /Visa interactive control.
I´ve followed the OHM60 document and enter the wanted parameters:
— 57600 bits per second
— 8 data bits
— 1 stop bit
— No Parity
Also entered the given commands from the document, (?:3010:00::c2) in order to read the temperature. But when sending Read/Query i get this error:
"Read Operation
Error
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed."
I´ve looked around this forum and googled for many hours but can´t find a solution.
Please help.
/D
Message 1 of 17
(4,576 Views)
Did you finish with a crlf or other endcharacter specified in the manual?
greetings from the Netherlands
Message 2 of 17
(4,567 Views)
My first thought is that you need to add a Line Feed to your command in order for the instrument to know the message is complete.
Otherwise, I recommend you post your code and we may be able to spot something that is wrong.
Message 3 of 17
(4,565 Views)
Thanks for the fast response!
I did not really write any code just wrote the simple command line as in the picture attached. What kind of Line Feed should I add ?
Sorry if I am a big ignorant, I am quit new to this. Thanks in advance.
I attached the page from the manual with the command syntax and so.
/D
Message 4 of 17
(4,560 Views)
Thanks for the fast respons!
No I do not think so, in the  Visa Test Panel I filled in the parameters and pressed the "Input/Output" tap, then enter my command which is the ?:3010:00::c2 as I mentioned and then pressed Query and/or Read. Which gave the error.
See picture "Visa test panel.png"
/D
Message 5 of 17
(4,557 Views)
Look at the manual on page 5-13.  Try adding the <CR> character to the end of your query.  It should work with the first line.  If not, try the other.
?:3010:00::c2\r
?:3010:00::c2\n
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 6 of 17
(4,553 Views)
I have tried "?:3010:00::c2<CR>" but not the /r and /n, I will try it and respond when I can. Thanks!
/D
Message 7 of 17
(4,551 Views)
/D
The "\n" when in "\ Codes" display represents a <CR><LF>.  Likewise, "\r" will represent a <CR>.  If you are in a normal/ASCII only display, this will not work for you.
Message 8 of 17
(4,546 Views)
Sorry but when trying to use \r and \n as you mentioned it does not work. Any ideas?
See attached picture: Visa test panel1.PNG
/D
Message 9 of 17
(4,516 Views)
Just to make sure, you are pressing the QUERY button and not the WRITE button?
Message 10 of 17
(4,508 Views)
