VISA: (Hex 0xBFFF0015) but is responding to *IDN?
I am using NI 488.2 GBIP controller
Whenever i try to commmunicate with the device it shows timeout error
While using Instrumentation and automation mode it responds to *IDN? but whenever I try any other command it again shows the same problem
When I try to open GBIP analyser it prompts GBIP+ analyser not connected
Message 1 of 9
(4,888 Views)
You are not providing enough information. What is the make and model of the instrument? What is a command (other than *IDN?) that you have tried? I hope you are not expecting a response when you issue a command that does not end with '?'.
Also, the analyzer function is only available for '+' type controllers - ie PCI-GPIB+. Use NI-Spy to monitor communication.
Message 2 of 9
(4,885 Views)
The instrument connected to the sysem is Agilent 4156C semiconductor analyzer
I am not getting anything on NI spy as well.
I am not able to understand that analyzer mode is only for +type cards
Can zou let me know how can I get data from Agilent analyzer to labview using PCI-GBIP
I am new to GPIB so please bear with me
Message 3 of 9
(4,846 Views)
other command whcih i am providing is
FORM:DATA ASC; SOUR:FUNC  SIN; SENS:DATA?
for whcih it shows timeout error
Message 4 of 9
(4,844 Views)
I've never used that instrument but I suspect it just isn't in a state that will return a measurement. You could try the driver.
Message 5 of 9
(4,831 Views)
how   to install the driver
i am quite new to this area please help
Message 6 of 9
(4,826 Views)
For the LabVIEW part, place the unzipped folder in your instr.lib folder. You'll also have to get the dll from Agilent.
Message 7 of 9
(4,824 Views)
do i need to place the dll in the same directory
Message 8 of 9
(4,820 Views)
No, you don't have to. The Agilent installer will probably place it in some default location and the LabVIEW wrapper will probably expect it there but you can place the dll anywhere you want and tell the LabVIEW functions where you have placed it. This is no different than any other LabVIEW VI with a Call Library function Node.
Message 9 of 9
(4,818 Views)
