11-06-2008 08:06 AM
I am using NI 488.2 GBIP controller
Whenever i try to commmunicate with the device it shows timeout error
While using Instrumentation and automation mode it responds to *IDN? but whenever I try any other command it again shows the same problem
When I try to open GBIP analyser it prompts GBIP+ analyser not connected
11-06-2008 09:00 AM
You are not providing enough information. What is the make and model of the instrument? What is a command (other than *IDN?) that you have tried? I hope you are not expecting a response when you issue a command that does not end with '?'.
Also, the analyzer function is only available for '+' type controllers - ie PCI-GPIB+. Use NI-Spy to monitor communication.
11-10-2008 07:26 AM
The instrument connected to the sysem is Agilent 4156C semiconductor analyzer
I am not getting anything on NI spy as well.
I am not able to understand that analyzer mode is only for +type cards
Can zou let me know how can I get data from Agilent analyzer to labview using PCI-GBIP
I am new to GPIB so please bear with me
11-10-2008 07:28 AM
other command whcih i am providing is
FORM:DATA ASC; SOUR:FUNC SIN; SENS:DATA?
for whcih it shows timeout error
11-10-2008 08:51 AM
11-10-2008 09:20 AM
how to install the driver
i am quite new to this area please help
11-10-2008 09:23 AM
11-10-2008 09:28 AM
11-10-2008 09:39 AM
