06-17-2009 02:02 AM
I had installed NI-VISA and it was working properly. In between i installed Agilent VISA and made it the primary VISA.
1)Now i uninstalled agilent VISA. and the VISA error: visa32.dll is not found. is coming.
in C:/Windows/system32/ ,only visa32.dll back up is present.
I have the labVIEW also installed on my system.
I read through the problems others are facing , and tried uninstalling only NI-VISA through add/remove programs in control panel. I could not uninstall only NI-VISA.
2)I have the third Quarter 2008 disk1-4 with me. In disk-4 , there are different folders with naming-->aug3-4 etc .
and each one has different NI-VISAs. which one should i use?
3) While trying to install, NIVISAdevsupport.msi , it asked to insert disk-2. We have only 1 drive, what is the other possible solution ?
Please help me solve this problem.
06-18-2009 03:55 AM - edited 06-18-2009 03:57 AM
i'm working on both VISAs no the same computer and have no errors
i'll give you a trick and i hope it might work with u
in the MAX , go to the VISA options and check the NiVisa Tulip.dll box , then click on Save
the same should be done with the Agilent Visa, Go to Tools>Agilent 488 and enable the "Enable Agilent GPIB cards for 488 programs"
if this didn't work , i'd rather ask you to get the latest VISA for both Agilent and NI ,
there is a difference between installing the VISA and installing the 488 standard
