10-04-2017 04:23 PM
Hi all,
I'm trying to control a VICI microelectric actuators for Selectors (Multiposition Valves).
I have try the example Simple Serial.vi and it works well. I found this file from the forum but it missed some *.vi, like SP Driver.vi and SP parameters has some problem. Is this because the version issue or where I can find this vi.
Best,
ChrisY
Solved! Go to Solution.
10-04-2017 05:06 PM
Never mind. How to close a topic?
10-05-2017 08:59 AM
Hi Chris,
I think you can just mark one of the comments as a solution. Otherwise, I wouldn't worry about it!
Thanks!
05-06-2019 11:18 AM
Chris,
How did you get the Sp driver.vi error and the parameters to work? I have a 2 position Vici valve and it's not switching positions
06-09-2021 09:42 AM
Hi, I would like to know how you solved this?
Many thanks
06-09-2021 09:43 AM
Did you figure this out?
08-11-2022 06:41 PM
Hi Chris,
I find the 4-pos serial valco.vi very helpful, and if you can share to me the missing files include SP Driver.vi and SP Parameters.ctrl, I will appreciate it!
Ella
