VICI Valve Conrol/ SP Driver.vi
Hi all,
I'm trying to control a VICI microelectric actuators for Selectors (Multiposition Valves).
I have try the example Simple Serial.vi and it works well. I found this file from the forum but it missed some *.vi, like SP Driver.vi and SP parameters has some problem. Is this because the version issue or where I can find this vi.
Best,
ChrisY
(3,757 Views)
Accepted by ChrisYuchen
Never mind. How to close a topic?
(3,736 Views)
Hi Chris,
I think you can just mark one of the comments as a solution. Otherwise, I wouldn't worry about it!
Thanks!
Timothy D.
Applications Engineering
(3,693 Views)
Chris,
How did you get the Sp driver.vi error and the parameters to work? I have a 2 position Vici valve and it's not switching positions
(3,034 Views)
Hi, I would like to know how you solved this?
Many thanks
(2,095 Views)
Did you figure this out?
(2,094 Views)
Hi Chris,
I find the 4-pos serial valco.vi very helpful, and if you can share to me the missing files include SP Driver.vi and SP Parameters.ctrl, I will appreciate it!
Ella
(1,332 Views)
