10-23-2013 04:11 AM
We are using Vötsch VTL 6010 climatic chamber and we want to control it via RS 232 in Lab View
The problem is the device is not responding for our commands we have done the following settings on the MINCONTROL LCD
Baud rate 19200/9600
Bus 01
tried ASCII-1 and ASCII 2 Protocols
configured the unit to External mode.
I am sending commands using VISA Control but there is no resaponse.IS there anything else I am missing .Kindly suggest me
Thanks in advance..
10-23-2013 11:29 AM
10-24-2013 01:43 AM
Thanx for the response
Regarding the Com settings I have set it according to the manual
"$01I<CR>"
This was the string which i have sent.
I have connected the serial db9 pin according to the pin diagram given.
Sorry for not giving the manual...
this time i have attached it below..:)
10-24-2013 12:03 PM
10-25-2013 01:20 AM
Thank you... it is working with ASCII 1 protocol... that will do for me... 😄
Cheerss..!
