Using ni-9232 with vs2005
I need to add an NI 9232 A/D to existing vs2005 c++ software. I added the example coding ContAcq-IntClk.c as a separate module. The example code starts with
        int main(void)
which I changed to
      int Run24Bit(void)
I start this as a thread, with the call
       hAD24=CreateThread(NULL,0,Run24Bit,NULL,0,NULL)
but following this (not before) call errors appear during execution.
I tried using     int WinAPI Run24Bit    instead, but that didn't work.
How to get this to run properly ??
Thanks for any help - Gil@Geonics.com
Message 1 of 1
(797 Views)
