Are you creating a
VISA TCP/IP resource in MAX? Also, what type of instrument are you connecting to? If you do add the
resource in MAX, you can use the Communicate with Instrument tool to test the
communication with your device. Simply send any command the device
should recognize, and see if you get the appropriate response in return.
Hope this helps!
Adam W
Applications Engineering
