Using VISA to Get/Put & Post http
Anyone know if you can get/put/post http protocol packets using the VISA Raw socket interface?
(3,166 Views)
Are you creating a VISA TCP/IP resource in MAX?  Also, what type of instrument are you connecting to?  If you do add the resource in MAX, you can use the Communicate with Instrument tool to test the communication with your device. Simply send any command the device should recognize, and see if you get the appropriate response in return.
Hope this helps!
Adam W
Applications Engineering
(3,144 Views)
