12-03-2010 09:47 PM
I have an application that is in VB6 but running under Windows 7. Is there a different DLL I should be using in this case? Windows 7 won't let me register the original gpib-32.dll...
12-04-2010 11:05 AM
You need a version compatible with windosw 7.
12-05-2010 05:23 PM
Thanks. I had a copy of the old version in the folder with my project. Most of the calls started working fine after I removed the local copy. I was having problems with the Send command. Is this command no longer supported?
12-05-2010 05:44 PM
The Send command is still listed in the help file. Can you use it in the NI-488.2 Interactive Control in MAX? do you get an error?
12-05-2010 06:41 PM
Just had the address wrong. Workinig fine now...
