‎02-05-2007 10:37 AM
‎02-06-2007 08:41 AM
UFO,
Have you been able to establish communication (and set the IP addess) when the ENET is not on the router?
If you can set the IP address to a known value (make sure its static), you could then connect it to your router and try to ping it using the ip address and then add it to your system if that is successful.
How are you currently trying to communicate with it? Are you just typing the name of the router? Also, does your network currently have a dns?
-Lamb
‎02-08-2007 08:41 AM
