取消
显示结果
搜索替代
您的意思是:
Unexecutable subVI for IET Labs PRS Series
ahamel wrote:
Once I removed the unwired Write VISA from Get PRS Model Info.vi , I started to have time out errors in the SCPI Command and Response.vi
Error code -1073807339: Timeout expired before operation completed.
This begins to make some sense!  As I mentioned earlier the PRS series has two distinct versions of the GPIB interface.  Only one of them is a Talker.  Also both versions have a distinct limitation- there is a local/remote front panel switch that must be set to "remote" for the GPIB to listen at all.
Make sure your not in the diet mode (i.e. LO-Cal) and take a look at the boilerplate on the rear.  What is the EXACT model of the unit?
"Should be" isn't "Is" -Jay
0 项奖励
11 条消息(共 17 条)
1,561 次查看
http://www.ietlabs.com/pdf/Datasheets/PRS.pdf
0 项奖励
12 条消息(共 17 条)
1,552 次查看
I have Model 2PRS-201-2IEE-2RO-2D
Though I have the dial set to remote, the local LED is the one currently lit up.
Message Edited by ahamel on 11-16-2009 12:15 PM
0 项奖励
13 条消息(共 17 条)
1,546 次查看
As I'm reading more into this, I see that the LOCAL indicator will remain on until communication with the unit is initialized.  Unfortunately, my initialize VI still returns errors.
Error Code:  -1073807339
VISA Read in IETPRS20X SCPI Command and Response.vi->IETPRS20X Query.vi->IETPRS20X Get PRS Model Info.vi->IETPRS20x Initialize.vi
0 项奖励
14 条消息(共 17 条)
1,537 次查看
"2PRS-201-2IEE"
http://www.ietlabs.com/pdf/Manuals/PRS%20im%20200%20IEEE.2%20complete.pdf
this is the SCPI version
check the TL dip switch on the back
Message Edited by Jeff Bohrer on 11-16-2009 12:58 PM
0 项奖励
15 条消息(共 17 条)
1,531 次查看
Forgive me if this is a stupid question, but is there no way to set the resistance remotely then?
0 项奖励
16 条消息(共 17 条)
1,526 次查看
I can change the resistance remotely through the string control on the front panel of the SCPI Command and Response.vi.
So, I think I can figure this out from here.  Thanks for the help
0 项奖励
17 条消息(共 17 条)
1,512 次查看
