08-01-2011 06:34 PM
I am trying to communicate with a device through an FTDI cable plugged into a USB port on my computer. It communicates with a serial port on the device. There are only the power, ground, and in/out wires attached to the device. The goal is to send a "\" character and get the serial number of the device back. The device is already programmed to receive this command and return the serial number, I just have no idea how to do this in LabVIEW. I get the feeling this is extremely basic, but I would really appreciate some help.
08-01-2011 08:14 PM
08-02-2011 11:29 AM
Are there USB read/write examples? I've been trying to decipher the Basic Serial Write/Read.vi file without success.
08-02-2011 12:00 PM
No such thing as a generic USB read/write and if you have the RS-232 version of the FTDI driver installed, all discussion of low level USB communication is just irrelevant.
What exactly are you have trouble deciphering? You select the VISA resource by clicing the pull-down, set the com settings (baud, parity, etc.), place your '\' in the 'string to write' control, and run the VI. If you get an error, report the error code. Assuming you have Context Help turned on, the controls, indicators, functions are pretty well explained.
08-02-2011 12:26 PM
Ok, so the biggest issue is that I can't find the device. I just installed NI-VISA and will explore it now. I couldn't find any ports or devices before, and I'm beginning to think that I need to find the device through VISA first.
08-02-2011 12:35 PM
Now I'm getting this error: Error -1073807202 occurred at Property Node in VISA Configure Serial Port (Instr).vi->basic_serial_write_and_read.vi
08-02-2011 12:43 PM
As the explanation for that error says, you have a missing driver and the missing driver is NI-VISA. Download it (click on the Support link above) or use the Drivers DVD that came with LabVIEW.
08-02-2011 12:46 PM - edited 08-02-2011 12:51 PM
I'll try installing from the CD, but I just installed NI-VISA and restarted about 15 minutes ago. I installed NI-VISA 5.0, and I'm running LabView 7.1. Could it be a compatibility issue? Also, I'm running Mac OS X if that makes any difference.
08-02-2011 12:53 PM
Did not know you were using such an old version. Yes, there is a compatability issue. Make sure to completely uninstall 5.0.
08-02-2011 12:54 PM - edited 08-02-2011 01:01 PM
Which version should I use then?
*Nevermind, I found that I should be using 4.2 or 4.5, I'll try 4.5 and see what happens.
