01-23-2007 05:28 AM
01-24-2007 07:15 AM
01-26-2007 02:31 PM
01-26-2007 02:58 PM - edited 01-26-2007 02:58 PM
Try babelfish and copy paste the page address and select French to English. Worked fine for me.
http://babelfish.altavista.com/
And it even translates the stars! So a French star is equivalent to an English star! ![]()
Message Edited by AnalogKid2DigitalMan on 01-26-2007 02:00 PM
01-28-2007 03:28 AM
01-29-2007 04:47 AM
01-29-2007 04:48 AM
09-18-2008 02:39 PM
Bump.
I'm seeing the same problem. I'm using the current VISA (4.4) on OpenSuse 10.3 (Which is officially supported).
The problem is, I can only run one "session" with the scope at a time. I can open the scope, send commands, and close the scope just fine.
If I want to open the scope again, it will open just fine, and allow me to set attributes (Time out etc) but as soon as I write a command, it times out. In order to bring the scope back online, I have to unplug the USB cable, and plug it in again.
I plan on running the scope from a remote location, so living with it, and physically unplugging each time is not an option. Were you able to find a solution rrado? Using LibUSB would be fine as long as I know I can get it to work before I go through the trouble of changing my code. Also, if there was a way I could simulate the unplugging and replugging of the USB cable (Restarting the USB service or something along those lines) that would be fine as well.
I should note that the scope works perfectly in Windows, no trouble at all.
Jeff
09-18-2008 03:01 PM
Ok, so I can restart the entire USB infrastructure (via rmmod "...", then modprobe "..."). This makes the scope usable again.
It would be nice to have the scope work without hiccups, but this solution meets my requirements for "acceptable."
Jeff
