USB-8452 SPI slave
I got a NI USB-8452 module for I2C & SPI.
I thought it can be used as SPI Master or Slave, but , while for I2C I see the manual mentions slave, I don't see this for SPI function.
Can it be configured to act as SPI slave ?  For what I want my PC / LabView to act as some slave device
(4,257 Views)
Yes I have SPI setup as a slave on one program and master on the other. It can be done.
Tim
GHSP
(4,166 Views)
Hey TIM,
Good to know. Any easy to follow tips for a LabView newbie .. ? Need to ramp up myself on this 'quick'.
Starting (yea, still starting stage .. ) on SPI basic examples, that came with the 845x driver / package installation.
I need to see if I can learn/do this within a time, or, just fall back to an external devboard may be.
(4,157 Views)
All I can tell you is that I pulled out the development document and set up SPI as the design required. I had one version where I had to take care of all of the clock timing and one where I waited for a digital line to change to tell me to read the data. I didn't think it was too hard to work with even wen the developer gave me the wrong information.
What are you having trouble with?
Did you get a document that tells you what timing to set your device to?
Tim
GHSP
(4,149 Views)
I guess my trouble is 1) all examples / documentation use SPI in LabView as Master , so no easy c&p  /no quick start with the Slave ..
(4,108 Views)
Hi @aeastet Tim
Can I know how you configured USB8452 as SPI Slave?
Please explain in detail.
(3,513 Views)
"The USB-845x devices cannot be used as SPI slaves." from
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kG5sSAE&l=en-US
(2,844 Views)
