USB-6525 Linux system with Visa Modules?
I was wondering if there was anyway to control the USB-6525 SSR system through the use of Fedora and a PC using VISA modules? I know that the DAQmx drivers are designed for use with a Windows OS based system, but I was wondering if there is any way to communicate with the SSR on a linux platform?
(3,666 Views)
Yes you should be able to interface usb devices with linux, you just have to install the DAQmx base driver, which can be found at the following link.
http://joule.ni.com/nidu/cds/view/p/id/2128/lang/en
Peter W.
(3,658 Views)
Could you, please, elaborate more on how to communicate with the USB-6525 through Linux? Is the answer valid for Ubuntu as well?
Bruno Lima
(1,618 Views)
