02-04-2008 02:44 PM
02-04-2008 02:56 PM
02-04-2008 03:23 PM
02-04-2008 04:05 PM
07-07-2008 09:48 AM
07-07-2008 12:36 PM
It is really easy to incorparate the LS model barcode scanner in Labview. I was trying to do this the hard way. You can simply read the serial number in a string control.
ramtekpr
07-07-2008 01:12 PM
08-22-2008 10:32 AM
I am using the same scanner- LS2208 and am having difficulties getting MAX to recognize the scanner. Can you give some tips on how you were able to get yours set up?
Very much appreciated,
Nathan
08-22-2008 11:14 AM
08-22-2008 11:51 AM
Thanks for the quick response. Someone I work with just showed me the same thing. Was making things much harder than they needed to be. I rolled back the driver I installed to the previous windows version and it works just like a keyboard
-Nathan
