Troubleshooting GPIB-USB-B Interface with Pyvisa
I'm trying to get a NI GPIB-USB-B interface to communicate with a lockin amplifer. I'm using an Apple Macbook Pro with Big Sur OS and the new M1 processor.
Whenever I open NI-Max, the software immediately closes. I haven't found a clear answer regarding whether or not my OS and/or processor is supported. Does anyone know if this is the case?
Also, incase it helps, I printed the log that pyvisa outputs and it's the following:
2021-04-12 11:25:49,726 - pyvisa - DEBUG - No visa library specified, trying to find alternatives.
2021-04-12 11:25:49,727 - pyvisa - DEBUG - Environment variable PYVISA_LIBRARY is unset.
2021-04-12 11:25:49,732 - pyvisa - DEBUG - Not loading dll_extra_paths because we are not on Windows or Python < 3.8
2021-04-12 11:25:49,733 - pyvisa - DEBUG - Automatically found library files: ['/Library/Frameworks/visa.framework/visa', None, None, None, None]
2021-04-12 11:25:49,733 - pyvisa - DEBUG - No user defined library files
2021-04-12 11:25:49,733 - pyvisa - DEBUG - The IVI implementation available
2021-04-12 11:25:49,733 - pyvisa - DEBUG - Not loading dll_extra_paths because we are not on Windows or Python < 3.8
2021-04-12 11:25:49,734 - pyvisa - DEBUG - No user defined library files
2021-04-12 11:25:49,736 - pyvisa - DEBUG - Library signatures: 90 ok, 0 failed
2021-04-12 11:25:49,736 - pyvisa - DEBUG - Created library wrapper for /Library/Frameworks/visa.framework/visa
Error Domain=KMErrorDomain Code=71 "Incompatible architecture: Cannot find arm64e in fat binary
Incompatible architecture: Cannot find arm64e in fat binary" UserInfo={NSLocalizedDescription=Incompatible architecture: Cannot find arm64e in fat binary
Incompatible architecture: Cannot find arm64e in fat binary}
Any help would be greatly appreciated.
Message 1 of 1
(1,937 Views)
