Timeout in ke2000 Data Read Single.vi in Keithley 2000 Multimeter
    I had the same problem working on Keithley 2000 instrument.
 My solution--->
   In Wait for SRQ.vi
        the Interface type selected by default was "Serial".
       I changed it to GPIB, as I am using GPIB.
 and its working.
 I hope the same works for you.
 Good luck
 Gourav
Message 11 of 12
(1,865 Views)
I have exactly the same problem/error message. My trigger is set to immediate and I use the exact same syntax given by keithley 2000 read multiple.vi
What was the solution in the end?
Message 12 of 12
(707 Views)
