01-25-2007 06:00 AM
01-25-2007 07:11 AM
01-25-2007 07:38 AM
Sorry, my post was too short 😉
I'm connecting it using a GPIB-USB-HS cable, my Visa version is 3.2 and MAX is 3.1.1, Labview is 7.1 (student version)
01-25-2007 08:28 AM
Do you have any other instruments connected and if so, do they show up after a scan? If they do show up, then I would first try connecting tge ITC510 by itself. If you don't have any other instruments connected, do you have one that you can test to see whether it's the GPIB-USB-HS.
I'm not familiar with the ITC510 but other things to check is to see what the address is set to on the instrument. Make sure it's not set to 0. Also, with some instruments you have to actually enable the GPIB from an instrument menu.
01-25-2007 08:39 AM
01-25-2007 08:50 AM
01-25-2007 09:00 AM
01-25-2007 09:30 AM
01-25-2007 09:49 AM
01-25-2007 10:11 AM
